check engine light on and off
Old Aug 31, 2011 | 08:34 PM
CAMBURT's Avatar
Unhappy check engine light on and off
would a bad catalitic converter cause check engine light to come on? it's a 94 camaro 3.4 with obd1 computer. i used a jumper wire to get the codes but it doesen't work, any help would be appreciated.
Old Aug 31, 2011 | 10:15 PM
Re: check engine light on and off
You'll likely need a real scanner to get the trouble code(s). When you do, you will know what is making the check engine light come on.
Old Sep 2, 2011 | 02:44 PM
There is no check in the OBD-I system for catalytic converter performance, so that is not likely to be the cause of the light.
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
