Cheapest aftermarket ECU?
Old May 4, 2003 | 03:39 AM
mastrdrver's Avatar
Just like the topic asks? It is for a TPI motor.
Jeremy
Old May 4, 2003 | 05:39 AM
TriPinTaZ's Avatar
Motec and ACcel both are in the $3000 range
can you use LT1_edit or LS1_edit? considerably cheaper then getting an aftermarket ECM
Old May 4, 2003 | 11:30 AM
madwolf's Avatar
He said TPI, so no LT1 or LS1_edit will work for him.
Do you mean aftermarket performance ECU or a cheap aftermarket replacement for the stock ECU?
Old May 4, 2003 | 12:21 PM
You might want to look at the Haltech for low $$$. I think it was originally intended for 4-cyl applications, but can handle 8-cyl applications if you give up individual fuel trim adjustment on individual cylinders. The Electromotive TEC-series is also not as expensive as the Accel-DFI or FAST. The MoTeC only scratches the surface at $3,000.... you need additional options that will easilly run it up to $5,000.
Old May 4, 2003 | 12:26 PM
mastrdrver's Avatar
I'm just looking for a cheap aftermarket replacement for the stock unit.
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
CARiD
Sep 30, 2015 05:44 AM
SEOJustin
Sep 24, 2015 04:39 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
