Cell 18??
Old Mar 4, 2005 | 03:49 PM
turbo_Z's Avatar
Cell 18??
I have been doing some data logs recently and noticed I am running in cell 18 at WOT.. why might this be? What is real strange is cell 15 shows in 2nd gear but then all of 3rd gear pull is in cell 18 and you can notice its not running quite as strong. MAF is showing less air flow and more vacuum is generated in the upper RPMs. In fact I am losing 8 KPA at 6000 rpm! Anything I can do to fix this?
Old Mar 4, 2005 | 05:22 PM
turbo_Z's Avatar
Re: Cell 18??
Before someone says its the PCM pulling fuel at WOT... I have locked cell 15 so it cant read rich or lean.
Old Mar 5, 2005 | 09:32 PM
Capt'n Two Rotors's Avatar
Re: Cell 18??
I too am running in cell 18 at wot after installing my headers and stall but am not loosing as much air as you I go from 101.8 to 97.4 at 6k. What is wrong with running in cell 18 at wot?
Old Mar 6, 2005 | 11:45 AM
97Z-M6's Avatar
Re: Cell 18??
if your using cell 15 at wot that means its adding fuel at wot. you want to be in cell 18. thats what the blm locker is for.
Old Mar 6, 2005 | 02:15 PM
turbo_Z's Avatar
Re: Cell 18??
Is it still in PE mode if youre running in cell 18? Even if I was in cell 15, it wouldnt be adding fuel b/c of the blocker. Datamaster shows cell 15 in say 2nd gear but when I hit 3rd its in cell 18. I am not concerned with adding/subracting fuel.. I just want to be sure whether its in cell 18 or 15.. is it still in PE mode. 15 I know for sure.. 18 I am not as 18 is also used in open loop.
Old Mar 6, 2005 | 06:39 PM
97Z-M6's Avatar
Re: Cell 18??
if your using the locker then look at the ccp dc.
Old Mar 6, 2005 | 08:36 PM
Doc99SS's Avatar
Re: Cell 18??
If you have an OBDII car, cell 18 is an idle cell, warm engine, AC on, M6 tranny. Why the PCM is in FTC 18 for you at WOT, I dont know. As an experiment, turn off the AC and see what cell you are in at WOT.
FTCs 0 thru 15 are part throotle cells, they all use fuel correction terms. For an OBDII car, the fuel correction is referred to as Long term Fuel Trim (LTFT) and Short Term Fuel Trim (STFT). For OBDI cars, its BLM and INT, respectively.
FTC 15 is also a transition cell to PE mode.
TFCs 16 thru 20 are special purpose idle cells, manual cars use FTCs 18, 19, and 20,,, A4 cars use FTCs 16, 17, and 18.
FTC 21 is the decel cell.
FTC 22 is the WOT PE cell.
Boss002
Jul 24, 2015 10:47 AM
hcarrickz3
Jul 21, 2015 08:46 AM
BLOWNBIRD
May 28, 2003 01:02 AM
ryaskovic
Jan 4, 2003 08:02 PM
rpm4lalo
N2O Tech
Sep 16, 2002 11:26 AM
