Cant scan 95 TA with AutoXray 2000
Well yea i just figured i would get rid of the crappy scanner and just get freescan and the cable for the car. Its not showing a check engine light now.. so no real emergency. That scanner is a entry level reader and it shows!
It was something I just had laying around that would fit.
Wow that is just not fair. I confirmed with AX that my software: 3.03 K 1.20 was the latest version of their software. Im thinking there might be a problem with my connector, or my reader is trash.What software version are you using? Can we verify you are using an AutoXray EZ Read 2000 ??
No, the wires were from something else that had a pin terminal already on them (from what, I don't know). If you soldered part of a fat paper clip (that would fit the DLC)on the end of the wire, it would probably work fine.
Thanks. But if LT4 swears he can scan his car with the same scanner and the blue cable then i must be an artard.
LT4: What is your 8th vin number/letter?
Mine is P which seems to not be what others have. Darn it!
That's why I suggested you try to adapt the other one. I have an older Autoxray that is essentially like yours (does I and II) and it works fine with the adapted cable. I never bought a "blue" cable.
Any f-body LT1 is going to have P in the 8th digit of the VIN. P = LT1
I try using the OBD I connector with the setup on your website and i get the same condition. The scanner says that the scan runs complete, but no codes are captured. Im starting to think the problem is not the cable, nor the diagnostic port. I think there is a problem with my scanner itself and the GM protocol.
Nayr
Mar 3, 2023 08:34 PM
tdigger9899
Sep 7, 2015 10:56 AM
