cant connect with akm usb
Old Jun 13, 2007 | 11:30 AM
Miles-'s Avatar
I am trying to connect using my usb akm cable and cannot get a connection to the pcm. I have taken off the usb connection and used a friends back half serial port and connection on his computer and it works, but nothing with the usb. Any ideas since my laptop only has the usb connections.
I used the guide on the akm website and did the tests and passed but sill not working. Am I missing something or does anyone else have any ideas?
Old Jun 13, 2007 | 02:00 PM
JAB's Avatar
JAB
In the software you're using did you set it to use the correct port? I know I had to set mine to port 5 using the USB cable.
Old Jun 13, 2007 | 02:04 PM
Miles-'s Avatar
yes I checked under the port section of device manager to see what port was being used
Old Jun 13, 2007 | 07:00 PM
stereomandan's Avatar
You loaded the all of the USB Drivers for the cable?
You restarted after loading the drivers?
Did you shut down the logging software and retry?
I remember when I tried Datamaster's Interface tester software to try my ALDL cable, it said that I was having problems, but when I tried Datamaster to log, and set the com port to 3 (for me) it worked just fine.
Dan
Old Jun 14, 2007 | 06:45 PM
Miles-'s Avatar
I downloaded the second driver on this page, http://www.ftdichip.com/Drivers/VCP.htm
I am using xp
I am assuming this is the correct one, anything else, the machine was restarted
Old Jun 19, 2007 | 06:52 PM
JAB's Avatar
JAB
What program are you using?
Old Jun 19, 2007 | 09:06 PM
Miles-'s Avatar
free scan
Old Jun 19, 2007 | 09:10 PM
JAB's Avatar
JAB
With Freescan you need to set the operational mode to Interact to get data. It's on the top right of the Control tab.
Old Jun 22, 2007 | 06:23 PM
JP95ZM6's Avatar
Did you get Freescan to work with your AKM USB cable? That's the route I'd like to go.
EDIT: Never mind, answer turned up later in my search. It works.
http://web.camaross.com/forums/showt...t=freescan+usb
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
drt
Sep 27, 2015 04:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
Bxlt1
Sep 10, 2015 08:16 AM
