Please take a look at 93 datalog
Old Jun 18, 2007 | 08:18 PM
jonlil77's Avatar
Finally took the car for its first run,been a long wait.Car runs okay but not right.the idle will not idle at the taget of 800 always higher and erratic.maybe iac possibly?when slowing to a stop it doesnt want to drop down to targeted idle.throttle stop screw is backed out so thats not it.there are two 1/4 inch holes drilled in the throttle blades to get it to idle without them the iac maxes and it wont stay running.fuel psi is 43 with vac line off psi regulator,slightly lower with it on.Car is very rich as you can see by the O2 sensors.Please take a look and point out any problems you see,I dont want to run this thing if it isnt right.Mail order from alvin,mods in sig Does anyone know his email I"d like him to take a look also maybe needs a retune? Links in csv and uni format.thanks anyone
.http://www.yourfilehost.com/media.ph...=First_run.csv or http://www.yourfilehost.com/media.ph...=trial_run.uni
Old Jun 20, 2007 | 03:19 PM
jonlil77's Avatar
ttt
nobody can take a look for me?
Old Jun 23, 2007 | 06:36 AM
smoknta's Avatar
You should check out www.speeddensity.org for some very specific info on 93 cars. I bet someone over there could help ya out.
Fastbird93
May 22, 2005 02:14 AM
BlackLT1_TX
Mar 26, 2005 12:04 AM
BlackLT1_TX
Mar 3, 2005 11:20 AM
BlackLT1_TX
Feb 18, 2005 01:29 PM
BlackLT1_TX
Feb 18, 2005 12:19 PM
