Can somone look at my data logs? BLM's
Old Aug 9, 2005 | 01:21 PM
Red on Red WS6's Avatar
I have tunercat for OBDII and Autotap for logging. I am trying to get my BLM's closer to zero.
It seem's I am running rich in a couple fuel cell and others look OK. Does anyone know what each cell controls? The O2's are only a couple months old and I cleaned the MAF with little change. Any suggestions welcome
Data log
Old Aug 9, 2005 | 04:41 PM
Re: Can somone look at my data logs? BLM's
The cells break down the engine operating conditions as a function of RPM and MAP (engine load). 01 is low load, low rpm. 15 is high load, high rpm. 16 is idle, 17 is coastdown and 18 is open loop "load" and default for fueling at WOT under some conditions.
There is a breakdown of the stock cell "boundaries" in my online scanner wirteup:
http://members.aol.com/InjuneerZZ/ScanMast.htm
Old Aug 21, 2005 | 11:12 PM
Thanks for the info Injuneer your write up is one of the best I have read and awnsered alot of my questions.
I am now wondering what kind of changes should I make to help with BLM's using Tuner cat.
So far the only adjustments I have made for fuel is lowering the values from 8 gms/sec to around 70gms/sec. This helped get my long term fuel trim (LTFT)
closer to zero but they are still split.
One other thing, I am using Autotap and the LTFT is labled in % I always thought a negative value ment it was running rich. Does anyone know if this is correct?
Old Aug 21, 2005 | 11:41 PM
A "minus" sign means the BLM is pulling fuel out in response to a perceived rich condition.
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
Sep 18, 2015 03:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
