Can someone help me out? 2.73 to 3.73 change
Old Jul 10, 2005 | 03:17 PM
S8ER95Z's Avatar
Tunercat? I changed the ratio and applied..then scaled all the MPH tables but im not sure if thats all I needed to do or not. I just found out you need to scale some tables and I wasn't sure what ones...so i did all the ones with 'MPH' listed in them... (Cold kickdown, etc)
Its for a friend since I don't have an f-body anymore... but he doesn't have a laptop. Thanks a lot!
Old Jul 10, 2005 | 04:58 PM
Tails's Avatar
Re: Can someone help me out? 2.73 to 3.73 change
In Tunercat all I believe you have todo is goto Tool > Speen Calibration, input your gear ratio in the Gear Information Field, hit the Calculate button to make sure everything looks right, then click the OK button.
Make sure the tire size is correct also..
Tails
Old Jul 11, 2005 | 12:06 AM
S8ER95Z's Avatar
I did that already..>I thought you had to scale the mph tables to make it all work though?
Old Jul 15, 2005 | 07:20 PM
gmr speed's Avatar
No you dont have to scale it. Just put the tire size and gears in and hit calculate then apply.
blac94Z
29
Mar 25, 2015 04:21 PM
Jul 4, 2005 05:00 PM
DETROIT_AREA_00_SS
Aug 14, 2002 08:00 PM
