Can an ECM be programmed for a different year or type of car?
Old Aug 29, 2002 | 08:41 AM
Bryant's Avatar
Post Can an ECM be programmed for a different year or type of car?
I need a '98 F-body ECM and I'm wondering if I can use one from a different year and have it reprogrammed. Can it be changed from 6-speed to automatic? That might make it easier to find. Also, could it come from a truck?
Old Aug 29, 2002 | 12:18 PM
Dr.Mudge's Avatar
Post
The PCMs changed in 2001 I believe, so I'm not sure how far you want to go with this. The easiest way to find out, look at the model number on the PCM, 16180815 or whatever, and match them up. As far as going from 6 to auto, I'm not sure, I know that you can go auto to 6 easily enough.
Old Aug 29, 2002 | 02:12 PM
Bryant's Avatar
Post
I'm installing the engine and automatic trans in a '40 Ford street rod. The aftermarket wiring systems recommend a '98 computer. I'm just wondering if there are others that can be used.
Old Aug 29, 2002 | 03:18 PM
kevin97z28's Avatar
Lightbulb
the breakdown of PCM's for the F-Body are as follows:
1. 94-95 PCM's are interchangable
(T-side/E-side 512's on both sides)
2. 96-97 PCM's are interchangable
(T-side/E-side 512 on E -side and 010 on T-side)
3. 98 PCM can ONLY be used with 98 (Only 1 Flash chip on ECU)
4. 99-2000 PCM's are interchangable (Only 1 Flash chip on ECU)
5. 2001-2002 PCM are interchangable
Its been a while, but i used to know this by heart, I am EX Hypertech employee...My duties in engineering was Re-flash "fried" PCM's.....now an FAST (Fuel Air Spark Tech) employee......KEVIN
Old Aug 30, 2002 | 08:42 AM
Bryant's Avatar
Post
Thanks for the info. I guess I'll start looking for a '98.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
97SSdude
Dec 31, 2014 07:43 PM
Dec 23, 2014 07:52 AM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
