Caddy PCM Swap
Old Sep 28, 2005 | 09:23 AM
AndyJ's Avatar
Caddy PCM Swap
I have a PCM out of an OBDI Caddy that was an engine donor.
Question is will that PCM work in a 96 F Body (OBDI) conversion that has a failing PCM?
Also, the failing PCM has a tune. Can I download the current settings from the failin PCM and flash the Caddy PCM? I have the AKM cable and software.
Car in question is 96 Z28, A4, OBDI Conversion, 160 tstat, CAI.
Thanks!
Old Sep 28, 2005 | 09:40 AM
turbo_Z's Avatar
Re: Caddy PCM Swap
As long as the service numbers on the PCMs match then you can do it.
Old Sep 28, 2005 | 09:52 AM
AndyJ's Avatar
Re: Caddy PCM Swap
Turbo Z,
Service #'s match. The second set of numbers on the lower, non attached part of the tag do not match.
Please excuse my ignorance as this PCM tuning is new to me. The failing PCM was converted from OBDII to OBDI. Can I use the OBDI PCM as a direct replacement or do I have to go through the conversion from II to I yet again?
Old Sep 28, 2005 | 12:29 PM
turbo_Z's Avatar
Re: Caddy PCM Swap
You cant convert a PCM from OBD2 to OBD1 or OBD1 to OBD2. What you can be done however is modifying an OBD1 PCM to work with the OBD2 knock sensor since its the only real compatibility issue... dunno why this is done when you could just replace the knock sensor but some people offer this service.
If tahts what you are referring to as the conversion then youll just need to pick up a 94-95 knock sensor... the sensor in the pass side of the block.. not the knock module in the PCM.
Old Sep 28, 2005 | 01:16 PM
sssalah's Avatar
Re: Caddy PCM Swap
It will need to be flashed with an f-body tune.
KamikaZ28
May 28, 2015 12:45 AM
jayvar
Feb 2, 2015 10:00 PM
Ricardo
Nov 29, 2014 10:58 AM
mikezero
Aug 6, 2002 06:10 PM
pnbarbee
Jul 9, 2002 06:35 AM
