PCM Bad?
Old Sep 28, 2005 | 10:35 AM
Husker_9495's Avatar
PCM Bad?
How do you check to see if the PCM is good. I'm told it is bad. I have a hypertech programmer (which the pcm responds to) , no scantool or software. Should i use something like lt1 edit or a scantool?
Old Sep 28, 2005 | 12:31 PM
turbo_Z's Avatar
Re: PCM Bad?
If the car runs then the PCM should be fine.
Old Sep 28, 2005 | 05:51 PM
Re: PCM Bad?
Can you tell me about failed emission NOx. Cat is new, EGR is functioning.
Don't know where to turn......
Old Sep 28, 2005 | 09:46 PM
infinitebird's Avatar
Re: PCM Bad?
Did you let it warm up enough before the test?
Are there any other known issues with it? Does it run well?
TitoPR221
May 26, 2015 12:20 AM
Zuvell
May 15, 2015 08:18 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Jan 5, 2015 07:14 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
