BLM counts normal?
Old Aug 3, 2007 | 01:52 AM
'94 Bad A Z28's Avatar
BLM counts normal?
I'm just getting in to all this tunning/scanning stuff. Are BLM's supposed to be split at idle or should they be the same? Mine are Left/Righ - 146/155 is that about normal?
Old Aug 3, 2007 | 10:56 AM
MEAN LT1's Avatar
That looks pretty normal to me, thats what mine pretty much look like. You get your T/C working correctly?
Old Aug 3, 2007 | 01:36 PM
No, still just using a switch. I still haven't been able to load up my new tune from Ion @ MadZ28. It's in *.bin format but TunerCat says that it's not the correct format or some crap like that.
Old Aug 3, 2007 | 01:44 PM
MEAN LT1's Avatar
Hmm, I have some .bin tunes on my desktop at the house. When I home i can send you a file to see if you can load it?
Old Aug 3, 2007 | 01:51 PM
You want the BLM's as close as possible to 128, and as close as possible to each other. Your's are terrible. The PCM is being forced to add 14% extra fuel on the left side, and 21% extra fuel on the right side. That means either there is a true lean condition, and the PCM really needs to add all the extra fuel to keep it at 14.7:1, or there is a false lean condition, caused by something like misfires, exhaust leaks before the O2 sensors, faulty sensors, etc.
Old Aug 3, 2007 | 02:06 PM
wrd1972's Avatar
Like injuneer said that is NOT normal, normal would be much closer to 128/128 give or take a few.
Mine are very high at idle and much closer to 128/128 everywhere else most likely due to the cam.
Old Aug 3, 2007 | 02:09 PM
It's not that it wont load it, but it wont even open it up. I'll go try to open it up and copy the message it gives me and post it here.
Old Aug 3, 2007 | 02:21 PM
This is the message I get when I try to open my *.bin file that I am trying to load in to my PCM.
Originally Posted by TunerCats
The ECM Definition file in use is not compatible with the source file. The file indicates that the $EE ECM definition file should be used.
Any ideas?
Old Aug 3, 2007 | 03:09 PM
wrd1972's Avatar
Any ideas?
You need to purchase the $ee (LT1 file) plug-in from tuner cat to access the LT1 files. Costs $20.00 from tunercat.com
Old Aug 3, 2007 | 03:16 PM
So what is the point in the free trial if you can't even use the trial to do anything?
Ohwell.
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 10:09 AM
Hal Fisher
Sep 30, 2015 09:03 PM
SEOJustin
Sep 24, 2015 04:39 PM
plattted
9
Sep 20, 2015 11:23 AM
