BLM counts normal?
I'm just getting in to all this tunning/scanning stuff. Are BLM's supposed to be split at idle or should they be the same? Mine are Left/Righ - 146/155 is that about normal?
That looks pretty normal to me, thats what mine pretty much look like. You get your T/C working correctly?
No, still just using a switch. I still haven't been able to load up my new tune from Ion @ MadZ28. It's in *.bin format but TunerCat says that it's not the correct format or some crap like that.
Hmm, I have some .bin tunes on my desktop at the house. When I home i can send you a file to see if you can load it?
You want the BLM's as close as possible to 128, and as close as possible to each other. Your's are terrible. The PCM is being forced to add 14% extra fuel on the left side, and 21% extra fuel on the right side. That means either there is a true lean condition, and the PCM really needs to add all the extra fuel to keep it at 14.7:1, or there is a false lean condition, caused by something like misfires, exhaust leaks before the O2 sensors, faulty sensors, etc.
Originally Posted by MEAN LT1
(Post 4780137)
Mine are very high at idle and much closer to 128/128 everywhere else most likely due to the cam. |
(Post 4780487)
It's not that it wont load it, but it wont even open it up. I'll go try to open it up and copy the message it gives me and post it here. |
This is the message I get when I try to open my *.bin file that I am trying to load in to my PCM.
Originally Posted by TunerCats
The ECM Definition file in use is not compatible with the source file. The file indicates that the $EE ECM definition file should be used.
Any ideas? |
Originally Posted by '94 Bad A Z28
(Post 4780590)
Any ideas? |
So what is the point in the free trial if you can't even use the trial to do anything?
Ohwell. |
