b-body pcm's
Old May 16, 2004 | 04:11 PM
simple's Avatar
b-body pcm's
getting ready to do the OBD2 to OBD1 swap
and i'm wondering if the b-body puters can be made to work with for the f-bodies? i can get them cheap locally...
my knock sensor is deleted so i belive all i need is the actual pcm right?
thanks
Old May 16, 2004 | 05:44 PM
madwolf's Avatar
Yes, those will work.
Your knock sensor was only deleted through programming, so you will need to switch to an OBDI KS or disable it through programming again.
Old May 16, 2004 | 11:15 PM
simple's Avatar
thanks Ion, thats what i wanted to hear
i'll prolly just delete the KS again thru programming
Old May 17, 2004 | 12:29 AM
simple's Avatar
Ion, with Tunercat how do you go about deleting the KS?
Old May 17, 2004 | 04:08 AM
madwolf's Avatar
Just delete the Knock Sensor Diagnostic, 43 code in the ECM Switch Table then zero out all tables from Knock Fast Attack Rate down to Traction Control Spark Retard.
Old May 17, 2004 | 08:34 AM
simple's Avatar
thanks again Ion
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
