Anything I can do programming wise to increase my off-the-throttle vaccum??
Old Apr 21, 2003 | 02:05 PM
Joe Brodman's Avatar
GP Moderator
Exclamation Anything I can do programming wise to increase my off-the-throttle vaccum??
Simply put, my brakes suck. I've never thought they were great, but now that the cam has been in the car, they are just terriable.
I don't have a vaccum gauge, but do have an electric fuel pressure gauge, and since fuel pressure is related to vaccum, the lower the pressure, the more the vaccum. Whenever I downshift hard and my fuel pressure drops, my brakes are always more firm.
So, anything I can do to help with this programming wise? Buying an electric vaccum pump is not an option; I have no money to spend. But I can program until my heart's content. Perhaps pull/add timing in certain areas. Increase my rolling idle a bit? Or a million other things I'm not thinking of.
Old Apr 21, 2003 | 06:03 PM
Dan K's Avatar
Start playing with timing....probably closed TPS spark advance.
Old Apr 24, 2003 | 11:49 AM
Hot Rod Hawk's Avatar
Yes , more idle timing. ( closed throttle timing table ) I've run 44 degrees with a cam cl of 104 with 4 degrees ground into it. This got it to pull 12 inches at idle.
For better braking use the "Throttle follower vr's mph table.
Raise the value a couple of points higher in the 10mph to 25mph range, this will force the iac to stay open a few more counts than that of the actual value seen on a scanner priour to adjusting. Watch the iac on coast down and you'll see how that table works....... IT WORKS GREAT.
If you raise the 0-10mph area to much it will be like driving with your foot on the gas!
Hope this helps
HRH
Old Apr 24, 2003 | 12:27 PM
GP Moderator
Hope this helps
HRH
Awesome. I'll try all that and see if it helps any.
Old Apr 24, 2003 | 02:15 PM
Dr.Mudge's Avatar
Timing is probably off, the Camaro brakes suck but mine was hardly different from before heads/cam swap, and I ran a similar setup. Just keep working the timing (slowly, in SMALL clusters) and watch the MAP.
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
Kawi
Sep 28, 2015 09:01 AM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
Aug 24, 2015 06:41 AM
