Anyone using a open loop tune
Are you asking whether you should run in open loop permanently? Never on a street vehicle. However, when leaded fuel is used, or O2's are impossible (such as a water-jacketed exhaust), it has to be open loop, but be aware that open loop tuning has no fuel correction capability, and you'd better be right on the money as far as fuel goes.
Not pertinent to answering his question, though.
AHARTZ28 seems to be doing just fine with his.
As far as open loop. Why do you want to run open loop? On a mostly stock car I don't think it would be much of a benefit.
If you have your heart set on it, you'll probably need to do it with a wideband to do it fairly well.
Seems like most of the people running open loop are doing it due to large cams and trying to clean up part throttle and idle stuff.
I think the best reason to do it would be to eliminate the O2's on a car that runs on leaded 100% of the time.
Originally posted by Dan K
How is that? The question is if anyone is using an open loop program and how it's working for them.
Data logging and tweaking the pcm is fun and I'm addicted.
armedtrigger
Feb 24, 2015 08:30 PM
Redbird
Aug 13, 2002 03:29 PM
