Anyone Care to Look @ my Log? :)
I had my car tuned by PCM4Less, but since then I have put on Longtubes and I'm sure it's not perfect
not even close, so if anyone would like to look @ it and tell me why my LTerms are @ 146
and my STerms are @ 164
I'd would appreciate it
Now I have little knowledge on tuning so far, but are the L/STerms suppose to be frozen @ 134/128 while in open loop waiting for the 02s?
Anyhow the log I got is from it idling in the garage about 15 minutes. It goes into Closed loop, then right back into open. But while in Closed loop the L/STerms rise from 134/128 to the numbers I mentioned above!
A noob question, 128 is stoich 14.7:1 A/F right? So the higher the L/STerm numbers, the leaner it is? And lower than 128 is rich, correct?
So if that's right, then my car is running LEAN in closed loop... any suggestions or willing people to look @ my log? I can provide it in .UNI or .CSV.
THANKS A MILLION!
THANKS A MILLION!
Re: Anyone Care to Look @ my Log? :)
If you can e-mail me a .csv version of the file, I will look at it. Be sure the subject line tells me what it is, because I generally delete attachments.
Sep 18, 2015 03:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
