Any MAP over 60KPa is causing knock, but why?
Old Jun 2, 2004 | 09:36 PM
ZPaul2Fresh8's Avatar
Ok got a tune from PCM4Less for a 94.
Anyhow it has LE Heads, Joe O cam on a 381 Bottom. Loaded the tune up, BLMs are split a little and the Left bank keeps rising to the 160 point.
I'm not really concerned about that bceause I know how to fix that, just about the knock that occurs every time the motor is over 60KPa.
It has a sufficient fuel setup and is running 94 Octane on a SCR of 11:1...
Any help would be greatly appreciated, thanks.
Old Jun 2, 2004 | 09:57 PM
jonaddis84's Avatar
Here is the datamaster log of a run with 15* of timing taken out from the original tune, im down to below 24* of advance across the board and its still knocking.
http://www.geocities.com/jonaddis842...degreesout.uni
What I know for sure is that when I took out 5-10* I could hear it spark knocking for sure. It either went away a little bit, or got fainter when I went 15* out but im 90% sure its still there.
KYWes
Jun 14, 2022 06:52 AM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Jocofire1
Aug 7, 2015 03:16 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
asilomar244
Jul 12, 2015 05:53 AM
