AKM cable software?
Old Aug 1, 2007 | 12:37 AM
'94 Bad A Z28's Avatar
AKM cable software?
Can someone send me the software needed for the cable to work with the PC/Laptop? I just purchased one off a local member but he could not find his install CD.
TIA
Old Aug 1, 2007 | 08:23 AM
Software to do what? Program? Scan? Datalog? I'm sure a simple search could give you a quick answer.
Old Aug 1, 2007 | 09:58 AM
MEAN LT1's Avatar
TIA
There is no software to make the cable work. Are you using TunerCat or LT1 edit?
Old Aug 1, 2007 | 11:07 AM
Maybe software wasn't the best choice of words, I meant that I needed the drivers for the cable. I looked through AMK's website though and he gave a link in case you lost the CD, so I got the drivers.
But I tried to load my program last night and I kept getting some weird error. Keept saying something about a port? Also somehting about the file not being in the correct format?
I am using TunerCat and the file is in *.bin format, I thought that is what TunerCat used?
Old Aug 1, 2007 | 11:08 AM
I don't know if it matters but the cable is the USB type. I am new to this so I have no idea about what to do to try to resolve this problem so I can load my program.
Old Aug 1, 2007 | 01:51 PM
You might want to e-mail Andrew at AKM to see if he can help.
Old Aug 1, 2007 | 06:48 PM
stereomandan's Avatar
You need to find out which port your AKM cable is using, and set your software to use that port.
I think it is explained somewhere on AKM's website.
Dan
Old Aug 2, 2007 | 09:56 AM
rngilliland's Avatar
If you can't open the bin file make sure you have PCM_EE or PCM_EEB selected under the ECM tab. The ECM_42 definition file that comes with Tunercat won't open a LT1 bin file. Most LT1 bin files use PCM_EE.
G-BODYT56
Jan 14, 2022 11:14 PM
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
