AC question
Old Sep 1, 2008 | 02:21 AM
kyleg001's Avatar
Question AC question
Does anyone know what psi (a/c refrigerant pressure sensor) and/or temp (A/C evaporator temperature sensor) readings are needed to engage the ac compressor clutch?
Old Sep 1, 2008 | 09:40 AM
bobdec's Avatar
These are not actual specifications.. rules of thumb, not from chevy books. The evap temp sensor should cut off the a/c at about 34* F and turn it back on at 36* to prevent freezing condensation on the coils. The low pressure cutoff is usually around 25-40 PSI (a fully charged system is 100+ (hi and low) with a/c off and 40-50 low / 200+ hi side with a/c on. Usually adding 1 can of 134 to an empty system will be enough to initially kick the compressor on then it may cut off as the low side pressure drops after running. Hope this helps..
Old Sep 1, 2008 | 11:12 AM
kyleg001's Avatar
Thank You
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
