95 OBD1 in 97SS
Old Oct 23, 2009 | 12:39 PM
7designs's Avatar
95 OBD1 in 97SS
What would it take to but a 95 OBD1 computer in my 97SS allowing me to tune this at a cheaper price?
Old Oct 23, 2009 | 01:06 PM
Swapping it in and changing the knock sensor (or have a resistor modification done to the PCM).
Old Oct 23, 2009 | 01:09 PM
7designs's Avatar
So no harness, just change pcm and knock sensor?
Old Oct 23, 2009 | 04:04 PM
I did not mention the harness, because it does not need to be changed. The only difference in the harnesses is the added OBD-II items (well, the coil connector is different, but that is moot when only changing the PCM). An OBD-I computer won't even look for those things.
Old Oct 23, 2009 | 07:55 PM
7designs's Avatar
Thank you for your help on this. Also your site is very helpful.
Old Oct 24, 2009 | 12:03 AM
97 RedSS's Avatar
Shoebox is exactly right like always! Ditched my obd2 6-7yrs ago, lol.
Old Nov 17, 2009 | 10:14 AM
7designs's Avatar
Another question,
When changing the knock sensor, will a stock sensor be ok with a cc 306 cam? I have heard some people running lt4 knock sensors because of cams. I know lt4 is for obd ii but is there something I need for running a cam like this?
Old Nov 17, 2009 | 04:10 PM
Originally Posted by 7designs
Another question,
There is no such thing as an LT4 knock sensor. The knock sensor is either for OBD-I or II. There is an LT4 knock module, though. You only need it if you are experiencing false knock.
Old Nov 18, 2009 | 08:43 AM
koolaid_kid's Avatar
You may want to consider this mod instead of replacing the sensor. Cheaper and will allow both OBDI and OBDII PCMs to work:
https://www.camaroz28.com/forums/sho...=OBD1+pcm+swap
Old Nov 18, 2009 | 01:51 PM
RalphBoggero's Avatar
excuse me guys, whats the correct resistor to get rid of the knock sensors ? is lt1 95
Old Nov 18, 2009 | 03:57 PM
94ZRagtop's Avatar
A 95 knock sensor is about 4k ohms, so a 3.9k ohm resistor does the trick if you want to remove the knock sensor altogether.
The 96-97 knock sensor is about 100k ohms, significantly different... so that's why you would need to solder the 3.9k in to a PCM in order to 'trick' the OBD1 computer to think that the correct sensor is in place.
whitehooptie
Aug 10, 2015 07:02 AM
Pullngz
Jul 26, 2015 05:55 PM
88IROC_Z
Jul 22, 2015 11:38 PM
sfGi8nt
Mar 15, 2004 03:27 PM
AHARTZ28
Nov 29, 2002 09:09 AM
