94 computer switch with 97
I should clarify - if it is a single read wire with a black connector, it is the fuel pump test connector. If it is a clear red connector with a gray outer shield, with a bunch of wires going into it, that's one of the PCM connectors.
anyways, what about the two sensors just sitting there zip tied up and out of the way???? One looks like the connector on the MAF, And the other looks like the connector that plugs into the Air Temp Sensor. I could not find exactly where they ran to... too tight of a squeeze. any Ideas?
posenheimer supposedly has an OBD2-->OBD1 conversion PCM, though. That generally means the PCM had the resistors soldered in it to account for the different knock sensors used in the OBD2 cars.
If posenheimer has an OBD2-->OBD1 conversion PCM with the resistors, no changes will be required. If the former owner installed a straight OBD1 PCM with OBD1 knock sensors, then posenheimer will have to change the knock sensors too.
man I hope they soldered them in. How do I go about telling????? Or not telling for that matter? Can I just get an LT4 knock sensor and put it in the ecu when I get it in the mail??
I don't assume he has anything. He has to find out just what he does have to make it work.
