93 z28 wont start
Old Oct 12, 2010 | 07:38 PM
hicks101's Avatar
93 z28 wont start
I have 93 z28 that starts for 15 sec. then turns off.It has a new fuel pump,opti,coil still loses power after 15 sec.
Old Oct 13, 2010 | 05:21 AM
Have you pulled any codes?
Old Oct 13, 2010 | 03:46 PM
hicks101's Avatar
no, some one told me it was the computer would that send a bad codes thanks
Old Oct 13, 2010 | 03:59 PM
moparman's Avatar
Here's how to pull the codes on a '93. You might want to save shoe's site, as it has some really good info.
http://shbox.com/1/dlc2.jpg
Old Oct 16, 2010 | 03:31 PM
bobdec's Avatar
ECM picks fuel pump repay pump 2-3 seconds when key goes from off to on , enough to pressurize fuel rails. After starting the opti pulses to ECM signal ECM to pick and hold the FP relay on. Opti or ICM DTC error codes will drop the FP relay and not light the SES indicator... Important to get a paperclip in there and check for codes. If no codes then the FP pressure is next thing to check.
Noenav
Mar 1, 2019 07:38 AM
HCz28
Jan 11, 2015 11:21 AM
tds1213
Nov 27, 2014 12:55 PM
Jul 4, 2005 05:00 PM
