93 Lt1 Pcm
Old Aug 3, 2003 | 09:15 AM
SantaCruz163's Avatar
93 Lt1 Pcm
I was wondering if 93 LT1 owners can use LT1 edit or TunerCat on their PCM? If not, how could 1 replace the PCM with a newer one from a junked car. I plan on building a heavier modded engine and I'd like to be able to use these PCM editing programs to tune my engine.
Old Aug 3, 2003 | 01:39 PM
wrencher's Avatar
NO..., the '93 are all unto themselfs.
They are ECM's with proms & are bank fire injection.
The 94's & up are eprom PCM's with sequntial injection .
The wiring harness for each are totally differant.
Old Aug 3, 2003 | 06:20 PM
So how would I tune my engine in a 93?
Old Aug 3, 2003 | 06:38 PM
Dan K's Avatar
This has been covered a couple of times but I can go through it again...
You can still get TunerCat you just need the DA3 definition file.
Then you need an eprom adapter like shown here: http://moates.net/gmecm/hardware.html
You can also get a couple of Amtel 29C256 chips from Craig too. These eliminate the need for a UV eraser and can be reprogrammed many times without a problem.
Then you need an actual eprom programmer. Check out The Pocket Programmer at http://www.xtronics.com/memory/EPROM.htm
That should be it. Of course you'll need a datalogger too. I'd recommend Datamaster as I have had great luck with it.
Any other questions, let me know.
Old Aug 6, 2003 | 11:25 AM
KCFormula's Avatar
Is tuner cat needed if you have the pocket programmer?
(So all that stuff is absolutly NEEDED?)
Old Aug 6, 2003 | 10:03 PM
Dan K's Avatar
Well, you can use the hex editor that comes with the pocket programmer but I'm not sure you'd have too much fun doing that.
Yes, you need TunerCat. I don't think there is anyway around it. And yes, all that stuff is needed.
You must have an adapter/board that allows you to plug your new chip into the stock computer. Then you have to have the actual chip you're putting on that adapter. That chip contains your program information. Then you must have an actual bin file editing program that allows you to make changes to your file. Then the programmer burns your new bin fle to the chip.
I would have told you that you needed it if you really didn't.
DirtyDaveW
Dec 1, 2016 05:37 PM
nikolt1
Feb 27, 2015 09:10 PM
willismoons
Feb 14, 2015 08:42 PM
Ricardo
Nov 29, 2014 10:58 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
