2 quick questions
Old Mar 18, 2015 | 12:50 PM
blac94Z's Avatar
2 quick questions
1. Is there a diagram for the wiring on the altnator the little red wire that come from pig tail . Voltage problem new alt.
2.is there a diagram for all the engine grounds i found that the ground strap on the front driver side of the motor was hanging and wasnt connected .
Old Mar 19, 2015 | 09:41 PM
Re: 2 quick questions
If you go right here, you can download the factory manuals for a 94 and have every diagram you ever wanted.
Old Mar 20, 2015 | 10:52 AM
blac94Z's Avatar
Thank you my good man but do you know what that strap goes to ?
I think it has something to do with my door locks , but i can be wrong
Old Mar 20, 2015 | 11:39 AM
Your question isn't clear.
1. You need a wiring diagram for the alternator - did you look at Shoebox's electrical wiring diagram section. 95 starting and charging wiring diagram is there, 94 will be the same. There is a red wire to the alternator that comes from the positive battery terminal. Is that what you are looking for? Or do you mean the red wire that comes from the instrument cluster?
http://shbox.com/1/starter_charging_95.jpg
2. As Rob points out, the factory manual has diagrams showing the grounding system, and drawings showing the physical routing of all the wiring in the car. Not sure how you would be relating an engine ground to a problem with the door locks.
If you look at Rob's diagram for the door locks, it tells you what page to look at in the factory manual to find the ground source. The manual will also tell you where ground G200 is located.
http://shbox.com/1/pwr_dr_lock_schematic.jpg
Sometimes you have to bite the bullet and do the research yourself. That's how the rest of us learned.
Old Mar 20, 2015 | 09:58 PM
GaryDoug's Avatar
Prominent Member
The strap connects the engine block to the car frame. The manual has all the details.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
