1996 Scanner Codes
Old Jun 1, 2003 | 06:44 PM
tohigh4you's Avatar
1996 Scanner Codes
I am trying to locate someone with current list of engine codes,etc for 1996 LT1. Im not sure if anyone would have a list typed up so I can diagnose a problem I have with a car i just picked up.
Thanks!
Old Jun 1, 2003 | 06:47 PM
blazzinbird's Avatar
I may have read that wronge
but if you know the codes please post them and i can tell you whatthey are
Old Jun 1, 2003 | 07:15 PM
tohigh4you's Avatar
i was trying to find someone who had alist they could send me...but here are my current codes....
p03004
p04414
p04434
these were read by superchips microtuner
Old Jun 1, 2003 | 08:02 PM
p-0300 is a engine misfire
p-0441 evaperation emisions control system incorect flow perge
p-0443 evaperation emisions control system purge control circut malfunction
Old Jun 1, 2003 | 09:18 PM
tohigh4you's Avatar
thanks for the reply....i guess my microtuner adds a 4 at end of each code.....i have the code list that came with my microtuner...its for 2002 but i guess codes must be same for 1996 because they match the list i have with microtuner....
thanks again....
i drove car this evening and it still has a slight stumble....it seems when car is cold.....when toeing into gas around 1800-2000 rpm it has a slight misfire that makes car seem jerky....once it reaches 2000 it stops.....any ideas....
thanks,
john
Old Jun 1, 2003 | 09:55 PM
tough to say, could be a opti, or maybe you need to change your plugs and wires
Old Jun 2, 2003 | 06:53 AM
tohigh4you's Avatar
i just bought the car a week ago.....opti was replaced by previous owner last summer when he replaced waterpump.....plugs/wires have over 50,000 miles on them since replacement....im thinking its wires/plugs myself.....now this is my first 4th gen,but ive heard terrible stories of how much fun it is to replace plugs/wires....anyone have any recommendations for which type plugs/wires to use....also, any idea of easiest way to accomplish the changeout....
thanks,
john
Old Jun 2, 2003 | 11:31 AM
I would recomend that you ask that in the lt1 section, sincei ti s no longer a computer problem..... I think the mods would appreciate that a little
aj2494
Mar 12, 2015 10:17 PM
Jazsun
Dec 29, 2014 12:14 PM
siguy
Nov 27, 2014 10:07 AM
91Bird305
Aug 5, 2002 01:39 PM
