1996 Camaro ECM cooling fan problem
Old Feb 7, 2010 | 06:16 PM
javlin98's Avatar
I have a 1996 Camaro 3.8L with a rebuild engine. The cooling fans don't come on and the overheats. I replaced the temperature switch. The relays are good. It appears that the ECM sends ground to the relay coils to pull in, but this doesn't happen.
Has anyone ever seen an ECM not work on just some channels? I can jump ground to the ECM harness on the DRK/GRN (slow) or DRK/BLUE (fast) and the relays pull in and the fans run, so its not the wiring.
Old Feb 8, 2010 | 07:29 AM
94ZRagtop's Avatar
Have you put a scan tool on it to see what the PCM thinks the coolant temperature is?
Could be that the PCM is not reading the coolant temperature properly. Check that before throwing more parts at it.
bernie1951
Dec 10, 2014 10:03 AM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
JasonD
Jul 15, 2002 02:17 PM
