1995 z28 obdII or obdI?
Old Jan 22, 2010 | 07:09 PM
mrl510's Avatar
Why am i seeing mixed opinions on 95 z28's being obII? I was told it was obd1. But i seen where GM put obdII in some cars before 96. Like here for instance: http://www.obdii.com/connector.html
If you scroll down you will see something about it.
Old Jan 22, 2010 | 09:19 PM
moparman's Avatar
Here's the GM list of OBDII '95 engines.
http://service.gm.com/gmspo/mode6/index.html
Old Jan 22, 2010 | 10:13 PM
Why? I guess it is because people are misinformed.
Originally Posted by shbox.com
The only 1995 f-body engine that is OBD-II is the 3.8L V6 that came out during the model year (replacing the 3.4L V6 that was OBD-I).
Old Jan 23, 2010 | 08:23 AM
DOOM Master's Avatar
I think you are mistaking that just because some 95 vehicles have the OBD2 style connector that it is running an OBD2 PCM. The only 95 F-body that came with the OBD2 PCM is the 3.8L V6. All 95 LT1 F-bodys have the OBD2 style connector, but are still using the OBD1 PCM.
Old Jan 23, 2010 | 10:44 AM
Airbornec507's Avatar
Originally Posted by DOOM Master
All LT1 F-bodys have the OBD2 style connector, but are still using the OBD1 PCM.
Lets get this straightened out before more information is given out that is not necessarily correct.
93 LT1 - EPROM OBDI
94 LT1 - OBDI connector and OBDI PCM
95 LT1 - OBDII connector and OBDI PCM - this is why many auto parts stores cannot scan 95LT1 pcm's for error codes. They don't know what they are really working with.
96-97 LT1 - OBDII connector and OBDII PCM
That's the LT1 line-up for you. The smaller v6 engines I cannot reference for you at this time.
Last edited by Airbornec507; Jan 24, 2010 at 05:03 PM. Reason: Excellent...now all the info makes sense.
Old Jan 24, 2010 | 11:20 AM
The post was only in reference to 1995 vehicles, but I can see how it might be taken incorrectly. I edited it to make sure there is no mistake it is for 95 vehicles.
93 LT1 - Flash pcm
Also, the 93 ECM is not a FLASH-based ECM, it is an EPROM based one.
Old Jan 24, 2010 | 11:23 AM
And its OBD-I.
Old Jan 24, 2010 | 05:05 PM
Excellent.....I'm glad both our posts make sense now.
Old Apr 19, 2023 | 02:04 AM
SteveTejeda's Avatar
Re: 1995 z28 obdII or obdI?
So is there a reader out there for one then? Cause I got a 95 z28 and it has the obd2 port. And I was there for like 5 mins looking dumb wondering why the car md thing I found in my house was throwing a reading error 😂
Old Apr 19, 2023 | 09:07 AM
There are dual-capability (OBD-1/OBD-2) scanners available. Typically come with correct cables. A used older OBD-1 (only) scanner will work, requiring either an adapter connector for the 16-pin connector, or you can use jumper wires, as shown on the Shoebox site:
http://shbox.com/1/xraycable.jpg
Avoid scanners made by Equus and Innova. Their LT1 database is incorrect and will typically return seven false/non-existent codes.
Avoid the Actron CP9001. It is just a box with a switch that shorts the DLC pins to flash the codes on the check engine light. 93 was the last year that will work.
Or, download free Scan9495 software, written specifically for the 1993-1995 LT1. You just need to have a PC and buy a cable:
https://www.camaroz28.com/forums/com...95-lt1-874306/
kuchak
Dec 6, 2011 01:02 PM
BMoney
Apr 18, 2007 02:02 PM
QCKZ28
May 16, 2004 06:54 PM
chevy1963
Sep 9, 2003 10:20 AM
YeahIDidIt
Mar 7, 2003 06:01 PM
