1994 z28 OBD-1 scan tool check
Old Aug 13, 2008 | 10:01 PM
94Z28KC4-GU5-PO5's Avatar
just wondering if with a 94z28 im SOL when it comes to a scan tool check or will some sort an adaptor like this http://shbox.com/1/xraycable.jpg work on my car?
thanks........
Old Aug 13, 2008 | 10:21 PM
is my only option with a 94z28 to hook it up to a OBD1 scan tool like at a dealership?
Old Aug 13, 2008 | 10:29 PM
There are OBD-I scan tools available that will plug directly into the 12-pin OBD-I port on your 94. Only the 95's, with their oddball 16-pin OBD-II style ALDL connector, but an OBD-I PCM require an adapter plug, or jumpers as Shoebox shows in the link you posted.
Auto X-Ray made a reasonably priced OBD-I scanner, and you can find them used for under $100. There's also the ScanMaster LT1 that wires directly to the ALDL connector data pin. Many of the newer OBD-II scanners are also OBD-I capable, with the correct cable. Actron makes a few. Auto X-Ray makes some.
Then there's free software you can download:
TTS DataMaster (free for first 20 uses)
http://www.ttspowersystems.com/
FreeScan (free)
http://www.andywhittaker.com/
Just get a cable from AKM Electronics.
http://www.akmcables.com/
Red Hawk 94
Mar 18, 2019 04:03 PM
Noenav
Mar 1, 2019 07:38 AM
cmdeshon
Jan 4, 2015 11:15 AM
thenewkid
Nov 27, 2014 09:41 AM
94z28jbw
Sep 8, 2002 03:22 PM
