What intake???
What intake???
Ok guys, I ran into a problem, and am gunna need a new intake... I need to be able to keep all my accessories, and be able to bolt my alternator all the way up, instead of just one bolt... < That is my current problem. But, that isn't really important. I was going to see what kind of intake you guys think I should use for my set up... Here we go, and chances are if I give it to you, it's all I know. lol Sorry, but this is what I have... And I don't have money to change my whole set up, so I am stickin with what I have, adding where I must.
I have a Holley 600 cfm carb,
282 Comp Cam,
stock exhaust manifolds,
etc... I have some more info in the sig.
Please help me if you can, and I know some of you guys know your stuff well enough to just tell me what I need... ThanX, and L8erZ
282 Comp Cam,
I have a Weiand Stealth intake on my 70 SS 350. The alternator bracket bolted right up w/no probs. I used to run a Weiand Team G. When you compare a Team G to a Victor Jr., the Weiand's ports are larger and don't usually need to be ported like a Vic Jr. does. I don't know about the dual planes though. I do like the concept of the Edebrock Air-gaps.
I don't think a performer rpm will fit under the stock hood. I have a torqerII single plane because it is the only one that would fit.(79' Z-28) At that the wing nut holding the air cleaner on put a small dent in the hood. It may work but just be aware of it.
GM makes performance manifolds, too. One would think they would work.
