Weird wiring problem
I'm having a weird problem with the rear running lights, and passenger side turn signal. All the lights in the car work fine, except these ones. The left rear turn signal works, but the right does not. The brake lights work (bulbs on high) but the tail lights do not (bulbs on low) I've checked all the grounds I can find, I've checked all the fuses, and I've made sure all the bulbs are definately working. I've cleaned out all the connections, but for some reason, I can't figure it out. If anyone has any ideas, it would be great. The car is a 1981 z28 4 speed.
I'm desperate for a fix, as the weather has turned fairly nice, and I'd like to drive it for a few days, as I've been driving my winter beater for a long time, and I'm going through withdrawl or a beefy v8. Please help me, cause I don't think I should put an insurance permit on it, till I have the lights working properly. Thanks again. Gord.
Well an electrical problem can be difficult to track down if you will go to www.nastyz28.com they have all the wiring diagrams for all 2nd gen cars. also if you post this question you should get a lot of input on your problem. I hope this can help .
I have a 81 z to and have a wiring problem all my lights work but when i turn my right turn signal on my head lights flash off and on with the flasher its a pain in the *** when you have a wireing problem and you cant figure it out
1981 Z 350 bored 60thou over flat top pistons 10 2 1 comp 202 valves 501 lift cam roller tip rockers 375 to 400 horse 373 posi with super t10 goes like hell
Yeah.. tell me about it. I've been trying to fix it for awhile now. I went through a automotive tech class post ed, and I excelled at everything except wiring. Geeze.. I Don't want to have to take it to a shop if ya know what I mean.
Magenta_Hearts
Mar 5, 2015 07:01 AM
