Weiand stealth or Edelbrock Performer
I buy a Edelbrock carburetor #1406 past month, and now I plan to buy a intake manifold, but have a dude:
Wich is the best manifold, Weiand Stealth or Edelbrock Performer with this carburetor?
In future I want to put a camshaft too and I don't know what camshaft can be good but this is for another occasion....
I want more power, but I want a street engine, not a racing engine and not only high rpm power.
Thanks.Fran.
Thanks.Fran.
Because you already have an Edelbrock carb, I'd go with the Edelbrock intake manifold - they are designed to work well with one another.
A regular air cleaner base sits too high and won't let your hood close, so you'll need a 'drop base' air cleaner and possible a shorter air cleaner element.
You may find that you also need a new throttle cable linkage.
The word 'dude' in english is slang for a guy or man. A better word for your first sentance is 'dilema'.
stick with the Edelbrock intake if u have an edelbrock carb, makes life easyer...
btw if u don't mind me asking why get a performer, when u can get a performer RPM for not that much over the standard performer?
If you put a large single plane intake on you will bog at low RPM when you accelerate hard. you will not get that with the performer RPM manifold though. It is a dual plane and small enough to keep enough velocity to make torque. I prefer the RPM over the stealth intake. Either one will support over 400hp. And as eric pointed out you will need a drop-base air cleaner and a new throttle-cable bracket.
CoryM
CoryM
I think a Performer RPM would be a better alternative for the Stealth. I have the Stealth manifold and an Edelbrock carb and I've always liked it, but I've never gotten to try an Edelbrock manifold. The only problem I had with the Stealth was that the hole for the alternator bracket didn't line up with my stock bracket, so watch out for that.
Originally posted by FRAN_Astur
In catalogue the performer rpm intake have a 1500-6500 rpm range,so if I drive the car in D gear under 1800-2000 rpm, (very frequently) What happen under 1500rpm?
Greetings.Fran.
Greetings.Fran.
In that case its more comparible to the Weiand Team G.
The Team G is comparable to the Victor Jr. The Performer is comparable to the Weiand Action+, and the RPM is comparable to the Stealth. The only difference is the name and the price, and the Team G's come with larger ports thant the Vic Jr. so you don't have to port them with aftermarket heads. Your carb will perform just as well with any comperable Edelbrock or Weiand intake. Just because your carb is Edelbrock doesn't mean anything, its basically a Carter carb. If brand matching mattered you'd be better off running Holley intakes with Holley carbs.
If you're planning on running a larger cam later, I'd either get a used Performer or Action+ or go ahead and step up to the Stealth or RPM. You won't really feel a difference with a small cammed engine unless you have over carbed. No sense in buying a new intake twice.
The drop base sucks on the Edelbrock carbs, it gets in the way of the fuel line unless you run a banjo fitting.
Get the performer unless you plan on changing the heads and cam in the future. Then step up to the RPM, but for now the performer should suit your needs very well. It is an easier install and should work well with the carb.
I had a Performer on the 383 in my '81, then I switched it to a Weiand Stealth. I actually felt like the Performer worked a little better because the torque would come on quicker, vs. with the Stealth the engine seemed to want to rev out a little more, but I didn't have a good enough carb (only a Q-jet) so it would lean out really bad at high RPM's...............I never had that problem with the Performer.
I think the Weiand Action Plus #8004 is the best bet. The port shapes are slightly larger and better than the Performer, but slightly smaller than the Performer RPM. The Action Plus will fit under the hood with no problem.
The Qjet is a fine carb- better for the street than any of the others, IMO. I could've easily fixed that top end issue. Mine pulls STRONG right through 6000.
).That was 3 years ago though, so it's a little too late to try and figure out
NewsBot
Jul 8, 2015 06:47 PM
CARiD
Jul 7, 2015 08:19 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
