Trouble with leaky 2ndary on holley 750
Old Jan 21, 2004 | 12:49 AM
WS6T3RROR's Avatar
so i'm tearing this 454 down for a guy, changing the cam etc etc. and i notice gas on the outside of the intake... it has the same slop in the shaft as all the other holleys i have laying around. i try not to worry about it until i pull the intake and on the back two cyl of the drivers side bank theres a puddle of gas sitting in each one. so i guess my question for you carb guys is what could make a holley leak fuel out of the secondaries while the car is off... it does it slightly while on but then while its off it leaks down and its hard to start after sitting... i mean no wonder with the puddle of gas sitting on the valve. i was thinking the fuel pressure might be set way to high or something. i mean thats all i can think of but it seems to do it especially on one side (dual plane intake). I'm open for any ideas... i have to tune this sucker after i get it back together.
Old Jan 21, 2004 | 10:56 AM
texlurch's Avatar
Sounds like the rear float level is set too high. If it is dblpmpr, it might also be missing the little needle/check valve in the accel pump hole. That gets lost on rebuilds fairly regularly...
Old Jan 21, 2004 | 12:41 PM
WS6T3RROR's Avatar
i was thinking it may be a combo between the rear float being too high and the fuel pressure being slightly high as well. its a vac secondary, and it shouldnt be missing anything since its basicly new and only had about 3 or 4 hours of run time.
Old Jan 21, 2004 | 01:23 PM
angel71rs's Avatar
Since it's a new install, might want to check for dirt in the inlet needle.
Old Jan 21, 2004 | 04:18 PM
SS69MAN's Avatar
If the needle is staying open along with pressure in the fuel tank ..........it might cause that as well
Old Jan 22, 2004 | 08:54 AM
n20ta2's Avatar
that would be my guess either needle plugged or float set too high if it was fuel pressure it would do it to the primaries as well.
Old Jan 24, 2004 | 08:06 PM
LT1 1980 malibu's Avatar
Corect me if im wrong but if the pressure was to high it would do the primarys 1st and then the flood the intake..I had this problem recently...
magman
Apr 15, 2016 03:08 AM
Ericksd
Jan 20, 2016 06:07 PM
95craz28
11
Sep 12, 2015 07:47 AM
Schul365
Aug 22, 2015 10:00 AM
240ssLs3
Jul 13, 2015 05:06 PM
