Steering Box
Old Mar 17, 2004 | 08:29 PM
orange68's Avatar
Steering Box
Ive got a 68 camaro w/ a 350 in it. I am trying to put in a new steering box after my old one locked up several times in bad situations. I took off the nut that attached the box to the pitman arm, 3 mounting bolts, the bolt that holds the clamp on the splined shaft to the column. The box wiggles but it doesnt want to take a direction out of the engine compartment. Has anyone done this project before with the engine in? If you have any suggestions on what to do next I would really appreciate it.
Old Mar 18, 2004 | 08:45 AM
roadblock's Avatar
Rather than try to remove the steering shaft at the spline connection, remove the two bolts at the rag joint in the steering shaft. I think that will come apart more ealisy
HibachiZ28
Nov 6, 2015 12:53 AM
zk06
Sep 9, 2015 11:39 AM
Aug 7, 2015 01:26 PM
alphaauto
Jul 26, 2015 04:40 PM
240ssLs3
Jul 13, 2015 05:06 PM
