Stall converter
Old May 13, 2008 | 11:21 PM
mike85z28's Avatar
Stall converter
How do I decide on what stall to go with on my 327?
Old May 14, 2008 | 03:19 PM
Rice Killer87's Avatar
Camshaft size and RPM range, as well as if its a street car or race car.
Old May 31, 2008 | 09:49 AM
stang_kllr's Avatar
dont forget rear gear ratio....
Old May 31, 2008 | 08:07 PM
Stephen 87 IROC's Avatar
Stall speed depends on the camshaft advertised duration and if it's race only or street/strip.
RPM range and gear ratio also depend on the camshaft, not the converter stall. The camshaft will dictate what everything else should be.
Old Jun 18, 2008 | 09:45 AM
mike85z28's Avatar
OK, thanks. I'm going to get an Edelbrock top end kit through Summitt, so Im assuming they will be able to give me the best matching stall. And I think im going with 373 gears.
Old Jun 18, 2008 | 04:37 PM
They should be able to.
Best to call TCI after you have your top end kit and tell them you need a convertor,they will ask you a bunch of questions about the setup/usage and they will be more helpfull than whoever is selling you the top end kit most likely.
Good luck!
Old Jun 18, 2008 | 04:52 PM
mike85z28's Avatar
Good luck!
Thanks I'm proly going to need it. I've never done this before. It's all new to me.
Old Jun 23, 2008 | 09:47 PM
Slick_Sammy's Avatar
there are lots of good converter companies. they will get you real close. for steet/strip a good 10" will be nice. I'd recommend giving Kenny a call at PTC down in Mussel Shoals AL. he'll get all your info. you can't go wrong with an ATI or Coan either but i stayed away from Coan after their rep told me a big line of total crap about only one company making a forward pattern TH-x shifter b/c forward patterns weren't any good by design (Coan rep claimed). PTC will also build you one from a used core for much cheaper but same quality.
thenewkid
Apr 12, 2015 07:42 PM
marine1bird
10
Jan 25, 2015 12:02 AM
Javier97Z28
Sep 8, 2002 07:23 AM
veryslowfbody
Aug 22, 2002 04:31 PM
TrouserSnake
Jul 22, 2002 05:34 PM
