Stall converter
Stall speed depends on the camshaft advertised duration and if it's race only or street/strip.
RPM range and gear ratio also depend on the camshaft, not the converter stall. The camshaft will dictate what everything else should be.
They should be able to.
Best to call TCI after you have your top end kit and tell them you need a convertor,they will ask you a bunch of questions about the setup/usage and they will be more helpfull than whoever is selling you the top end kit most likely.
Good luck!
Good luck!
Good luck!
Good luck!
there are lots of good converter companies. they will get you real close. for steet/strip a good 10" will be nice. I'd recommend giving Kenny a call at PTC down in Mussel Shoals AL. he'll get all your info. you can't go wrong with an ATI or Coan either but i stayed away from Coan after their rep told me a big line of total crap about only one company making a forward pattern TH-x shifter b/c forward patterns weren't any good by design (Coan rep claimed). PTC will also build you one from a used core for much cheaper but same quality.
Javier97Z28
Sep 8, 2002 07:23 AM
