Serpentine belt question for
Old Oct 21, 2002 | 08:35 PM
Boz69LT1's Avatar
Question Serpentine belt question for
I have a 94' LT1 out of a Camaro. I just installed an accesory bracket kit from Street and Performance. The setup orignally is from a Corvette. (The bracket that places the compressor, alternator, and the power steering pump on the driver's side.) This is in order for it to fit in my 69' Camaro engine bay. My question is if anyone knows what belt size I need to pick up. Also, if its not to difficult to describe, how does it loop through the pullies. I also noticed that this covers the place where my secondary air pump used to mount. Do I need this pump? If so, where does it go now? Help please!
Old Oct 23, 2002 | 10:42 PM
podany24's Avatar
re
Come on somebody has got to be able to help this guy out. He really needs to get this thing done.
Here's a TTT for ya Reg!
Old Oct 24, 2002 | 02:48 PM
Greg Nolte's Avatar
Belts are sold in inches and its not hard for a auto parts shop to figure out what you need. As far as routing, if the pulley is smooth its for the back side of the belt and of course if it is grooved it is for the grooved side. What I did was run a piece of string over the pulleys, taping them to each pully. My buddy wrenched the tensioner and I marked the string to get the length.
Old Oct 24, 2002 | 09:50 PM
96ltz's Avatar
Boz - you might want to check the alignment of the belt. I think the dampers might be different lengths from a Camaro to a Vette???
A good place to start on a belt would be to look up what fits the car you got the brackets from as long as you kept all of the belt driven acc. You can go up or down from there as nessacary.
Old Oct 24, 2002 | 10:02 PM
Boz69LT1's Avatar
I got a spacer from Street and Performance to bring the harmonic balancer out to the correct spot. I'll try the string idea, hopefully the guys at the parts store won't mind me coming back a couple of times. Thanks for the help.
Thanks Tony.
Magenta_Hearts
Mar 29, 2017 08:54 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
RUDEDOG
Parts Wanted
Apr 24, 2015 09:47 PM
grabbem88
Feb 23, 2015 09:41 PM
