Quadrajet fuel drips
Old Sep 13, 2006 | 08:21 PM
Danny McAdams's Avatar
I have a quadrajet that drips fuel at the nozzles in the boosters, I rebuilt carb because it was doing this, I made sure accelerator pump check ball seated and had the correct gaskets. Hey guys whats next? Thanks camaro409
Old Sep 13, 2006 | 10:46 PM
spinout's Avatar
Re: Quadrajet fuel drips
fuel pressure too high or float level
Old Sep 14, 2006 | 10:48 AM
markinkc69z's Avatar
A QJet has very sensitive primary boosters. A mentioned before it could be fuel/pressure or float level related. Did you replace the float during the rebuild? Its an extra cost option. Factory floats can lose some bouancy.
How does the engine run? If you've opened up the primarys to raise idle speed it could cause them to start pulling fuel at an idle if there's enough airflow through there.
Old Nov 1, 2006 | 09:23 PM
z282slo's Avatar
Ditto
kolbaso
May 21, 2015 01:49 PM
94Z28LS1toLT1
Feb 26, 2015 07:47 AM
carcrazyQT
Sep 6, 2002 07:30 AM
carcrazyQT
Sep 3, 2002 02:51 PM
JJ's Z
Sep 28, 2001 09:31 AM
