power steering adjustment nut leak
i have a 1969 camaro ss 396, put a rebuilt power steering box, the adjustment nut on top is leaking power steering fluid, how can this be fixed or do i need another box?
thank you
thank you
thanks
Guest
Posts: n/a
There is a rebuild gasket set that you can buy for it. I picked one up at the local Chevy parts counter, but that was back in the 80's. Classic Industries probably has one. I am not sure how much of a job it is to overhaul the unit and replace the gaskets. I ended up swapping mine out completely. I don't know if there is a gasket for the adjusting nut, I didn't think that there was...? If you just put that rebuilt unit on, I would take it back and get one that doesn't leak...
stockssn2o
May 25, 2015 08:54 AM
mspennyhughes
Mar 1, 2015 03:50 PM
SMO Q
Feb 11, 2015 07:13 AM
