power steering adjustment nut leak
Old Jun 3, 2007 | 09:28 PM
woodbine's Avatar
i have a 1969 camaro ss 396, put a rebuilt power steering box, the adjustment nut on top is leaking power steering fluid, how can this be fixed or do i need another box?
thank you
Old Jun 4, 2007 | 10:11 AM
angel71rs's Avatar
Pics???
Is the nut tight? Try holding the center screw with an allen wrench and tighten the nut. You want to hold the center screw so it doesn't lose adjustment when you tighten the nut.
Old Jun 7, 2007 | 06:50 AM
woodbine's Avatar
Originally Posted by angel71rs
Pics???
tried that, and it still weeps power steering fluid. is it hard to take the top off and change a seal? or any other idea's.
thanks
Old Jun 7, 2007 | 08:22 PM
CamaroRS_SS
Guest
Posts: n/a
There is a rebuild gasket set that you can buy for it. I picked one up at the local Chevy parts counter, but that was back in the 80's. Classic Industries probably has one. I am not sure how much of a job it is to overhaul the unit and replace the gaskets. I ended up swapping mine out completely. I don't know if there is a gasket for the adjusting nut, I didn't think that there was...? If you just put that rebuilt unit on, I would take it back and get one that doesn't leak...
Old Jun 9, 2007 | 11:19 AM
RAT454's Avatar
Are you using power steering fluid or tranny fluid?
G
Old Jun 9, 2007 | 06:47 PM
woodbine's Avatar
G
power steering fluid. i am trying a copper washer, still weeping a little.
Old Jun 10, 2007 | 11:20 PM
RAT454's Avatar
Might try a new copper washer and wrap the threads of the adjusting screw with teflon plumbers tape...It'll be a pain, but it should stop it from leaking.
G
HectorM52
Jul 30, 2017 11:46 AM
mspennyhughes
Mar 1, 2015 03:50 PM
XtremeLt1
Sep 13, 2002 08:50 PM
