OIl presssure fluctuation/valve tap/vibration=???
OK, engine in question is a small block, .030 over, decent hyd cam. Started out having a valve tap. Oil was changed, valve tap still present. Now oil pressure gage goes nuts while at cruising speed, is bouncing between 50-60 lbs. Has a fairly steady 30 lbs pressure at idle. And now there also seems to be a vibration right before shifting up to next gear. Any ideas?
Thanx,
ubg
Thanx,
ubg
RX Speed Works
Jul 24, 2015 02:25 PM
