New motor and tranny help! please
Old Apr 27, 2009 | 09:29 AM
User56898's Avatar
Hey guys
Finally purchased a new TKO600 perfect fit tranny kit for my bored and stroked T&L 408ci SBC making 510hp and 520ftlb
Few questions that i need help on and you advice would be GREATLY appreciated.
1) What motor mounts? Have a set of solid motor mounts or should i go with new energy suspension ploy mounts? Whats the pro and con of solid mounts?
-Trans comes with new poly mount
2) What altinator braket kit would give me clearance for my electric water pump?
3) Mechanical fuel pump still okay? New regulator/filter
4) A stock Big Block radiator with two electric fans okay?
5) what amps for a new altinator? (MSD ignition, 2 electric fans, electic water pump, alpine radio system, optimum battery in trunk)
Thanks for all the help guys!
Old Apr 27, 2009 | 12:18 PM
Z28SORR's Avatar
1) Depends on your tolerence for vibration. I would go with the poly.
2) Don't know.
3) Would think at least an inline electric would be required. That size fuel lines??
4) Would think you should be fine.
5) I personally wouldn't go with less then a 120A.
Old Apr 27, 2009 | 04:29 PM
User56898's Avatar
2) Don't know.
really? thought a mechanical pump would be fine. using a carb so only need like 9psi right? damn...electric= more $$$$
Old Apr 27, 2009 | 06:25 PM
Z28SORR's Avatar
6-7psi. It's not for the PSI, it's for the volume. A high performance mech. MAY work. That size carb.???
Old Apr 27, 2009 | 10:13 PM
User56898's Avatar
750cfm i believe
built by AED, dyno tuned to motor
all electric pumps require a return line to the tank? thats a PITA
Old Apr 28, 2009 | 11:00 AM
Z28SORR's Avatar
Originally Posted by 67speeda
750cfm i believe
Not true!
If you use this type electric pump, which has an internal bypass: http://store.summitracing.com/partde...5&autoview=sku
and this type NON-return regulator:
http://store.summitracing.com/partde...?part=MAA-4207
you do not need a return line.
And speaking of lines, it is recommended that you have at least a 3/8" feed line from the tank to the carb. Many of the older cars only had a 5/16" line.
These are just my recommendations, you can always try it with what you have! It's not that difficult to change later if it doesn't work out.
jmadoll
May 27, 2015 07:13 PM
BigWil
Mar 29, 2015 12:24 PM
92ragtop
Dec 27, 2014 01:56 PM
Snoman73
Nov 17, 2014 07:22 PM
