Need help with starter!
Old Feb 23, 2005 | 12:29 AM
thumper11's Avatar
Hey here my sad story. Mid summer I bought a 1979 Camaro. Steal too, 800 bucks for a great car, 305 engine, some what rust but nothing a good welder can fix. So Ihave the car for about two months, l was in the middle of stripping the interior when l went to start it, and nothing. My guess is the starter. However I am somewhat new at car, l want to take the starter off to see if thats the problem and try to clean it out and what not, does any1 know how to take off a starter from a 79 camaro? Thanks in advance!
Old Feb 23, 2005 | 10:16 AM
75 outlaw LT's Avatar
Re: Need help with starter!
It could be your starter.. but my guess is that your distributor/cap/coil has gone out. Is it trying to turn over at all? Could be that your battery is dead. My camaro sat in the garage during the cold season and wasn't cranked for a week and the battery died. Try that also. If it is trying to turn over it could be a number of things.
Old Feb 23, 2005 | 10:56 AM
thumper11's Avatar
Well it doesnt even turn over, so l figured it was either the battary or starter? I'm lost right about now
Old Feb 23, 2005 | 11:15 PM
IRONFIST's Avatar
Yah, well if it didn't turn over then it's something to do with the starter.. or that circuit. Most starter repair places can test it... should unbolt from the bottom.
Old Feb 24, 2005 | 04:54 AM
Well, when my battery died it wouldnt even turn over, just clicked a little. Turn the key to the accessories position and see if your radio works fine for a few minutes. If so, it's your starter.
Old Feb 24, 2005 | 01:33 PM
94Z28WP's Avatar
If it doesn't turn over at all I'd be looking at the battery and cables... Test the battery with a voltmeter or take it out and have it tested... If it tests out ok then check the battery cables... Check to see if they're loose... Also, if there's a buildup of corrosion on them, the starter can't draw enough current to turn the engine over... If all that checks out then check the starter... Removing it is pretty easy on those cars... You'll need to remove the shield that covers the torque converter, disconnect the wires from the starter, then just unbolt it and drop it down... Then you can have it tested.
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
