LT 1 timing tab?
LT 1 timing tab?
I have an 89 camaro with a 350 carburated. I am pretty sure that it is an LT 1. the only timing mark on the cover is I am assuming tdc. can I just buy a timing tab and time it that way. the balancer is marked
There is a tab welded to the middle of the timing chain cover? If so, no you can't use a regular bolt on timing tab. There were engines that had the timing tab welded to the cover, and these have to be used with a matching balancer that has the timing mark in a different place than balancers that were used in the much more common bolt on tab applications.
If you mix the 2 different types, you're timing mark will be way off. You could use a tool to find TDC and mark your balancer in a place to correspond with a bolt on tab.
Oh yeah, I presume this is an old style engine, not a gen 4 LT 1; don't know anything about those, skipped right to the LS1.
ChrisFrez
Feb 1, 2015 08:26 AM
Black Sunshine/ 00SS
Jul 17, 2002 08:41 PM
