LT 1 timing tab?
Old May 8, 2007 | 07:55 PM
sekou7x's Avatar
LT 1 timing tab?
I have an 89 camaro with a 350 carburated. I am pretty sure that it is an LT 1. the only timing mark on the cover is I am assuming tdc. can I just buy a timing tab and time it that way. the balancer is marked
Old May 9, 2007 | 09:07 AM
angel71rs's Avatar
There is a tab welded to the middle of the timing chain cover? If so, no you can't use a regular bolt on timing tab. There were engines that had the timing tab welded to the cover, and these have to be used with a matching balancer that has the timing mark in a different place than balancers that were used in the much more common bolt on tab applications.
If you mix the 2 different types, you're timing mark will be way off. You could use a tool to find TDC and mark your balancer in a place to correspond with a bolt on tab.
Oh yeah, I presume this is an old style engine, not a gen 4 LT 1; don't know anything about those, skipped right to the LS1.
Old May 10, 2007 | 07:46 PM
sekou7x's Avatar
the timing chain cover doesnt really have a tab its just a notch , it has no
degree marks or anything like that. Any suggestions?
Old May 12, 2007 | 08:06 AM
ayers1967's Avatar
It could be a gen 4 lt1 with a carb intake and hei type distributor. If you use a piston stop find tdc then bolt on a timing tab and use degree tape around the balancer.
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
Black Sunshine/ 00SS
Jul 17, 2002 08:41 PM
