I'm a Noob!!!! Sorta....
Old Jul 21, 2003 | 10:37 AM
  #16
grygst76's Avatar
Originally posted by camcojb
I know you didn't infer that I thought you were lying; since all you can do is read what I'm typing and not hear the tone of my voice, I wanted to make sure you knew I wasn't calling you a liar. Been wrong before and will be wrong again! I've just had several different engine and car combos, taken virtually everything I've built down the track more than a time or two, and never been able to get a combo like that to run that good.
Take care.
Jody
problem
This is one of the reasons I hope he is not just buying my car in hopes of doing consistent runs like I did or going by what she did on the dyno. In my past I was doing the same thing with cars such as 69 vette with the original 427, 72 LT1 z28, 70 chevelle and so on and so forth and found it incredibly difficult to squeeze every last bit of power out of them without trashing the motor. I had pistons blow thru heads; a rod literally smash thru the block; and the worst was the 427 when it almost craked the block in half!! All in all I have had incredibly good luck with 327's in general. I like the fact that they spin high like the 302's do and the use of forged internals. I've only owned 3 other 327's and each one did exactly what I wanted it to do as far as power. I wish I could still afford to buy engines and hook them up but the daughter put a huge damper on that!!
Old Jul 21, 2003 | 10:58 AM
  #17
95TA8280's Avatar
Don't worry Gary, I'm not getting the car to run consistant 11.2s or anything...I'm not much of a racer I've never even taken the TA to the track and that car is in the 12s. Don't worry about me spinning past 6900, it'll never even get close to that.
And, as your PM says, I still want the car
Old Jul 21, 2003 | 11:01 AM
  #18
95TA8280's Avatar
Oh yea, and the body work is cheap because my best friend works in a body shop. I can get the whole car painted($2000+ job) any color for much much less
Old Jul 21, 2003 | 11:07 AM
  #19
grygst76's Avatar
I just hope you don't think I'm being **** now, I just want you tro be happy with your purchase period. As a fellow gear head I will help you in any way possible to achieve your goals with her since she is still in my heart and she never let me down.
Old Jul 21, 2003 | 11:36 AM
  #20
95TA8280's Avatar
You've got a buying and I've got a car!
Old Jul 21, 2003 | 11:54 AM
  #21
grygst76's Avatar
I sent you an email.
Old Jul 23, 2003 | 02:31 AM
  #22
SSnthe10s's Avatar
i'll beleive it when i see it
Old Jul 24, 2003 | 12:21 PM
  #23
95TA8280's Avatar
You will see it when I dyno it
What do you think she'll pull?
Old Jul 24, 2003 | 12:26 PM
  #24
camcojb's Avatar
Well, it should make somewhere in the neighborhood of 380-390 rwhp if it's making 485 at the crank.
Let us know when you get it dynoed. Good luck!
Jody
blkWidow
Apr 20, 2015 09:27 AM
Xvirus
Apr 22, 2006 04:36 PM
always faster
Apr 4, 2006 12:34 AM
