I cant unlock my door!!
Old 08-05-2003, 06:35 PM
CamanZZ4's Avatar
Hello!! I have a 1969 Camaro that I am in process of building. I was installing the door locks today, and now I am in a bind. I had the lock in and everything, and I pulled the lock up to see if it would lock, and ever since then, I have not been able to unlock the door, therefore, I cannot open my door. I took the the keylock back out, but the door is still locked. When I play with the locking mechanism, it sounds like it is getting stuck on something solid, and will not let the moving part on the inside move at all. Has this happened to any of you? Please, and help would be greatly apprecitated. Thank you!
Adam
CamanZZ4 is offline
Old 08-06-2003, 08:17 PM
CamanZZ4's Avatar
Nevermind, I took the dremel to it, the lock no longer exists!! Thank you!
CamanZZ4 is offline
Aaront810
08-29-2020 09:34 PM
2QUIK6
09-17-2016 02:31 PM
RUENUF
03-13-2016 03:37 PM
IndyZman
10-22-2015 02:17 PM
z28cam1993
09-09-2015 04:08 AM
Quick Reply: I cant unlock my door!!
