How do I remove the ignition switch?
Old Apr 30, 2005 | 11:54 AM
stale's Avatar
I can't seem to get my damn ignition switch out of the dash on my '67 and I'm pretty sure it's burnt out. I put the key all the way left into ACC position like the manual says, and then I take a little 1.5mm allen key and stick it in the little hole. I can feel the plunger depress, but I can't turn the key left anymore. Is there some kind of trick that I'm missing or is this thing stuck forever?
Old Apr 30, 2005 | 06:26 PM
Stephen 87 IROC's Avatar
Re: How do I remove the ignition switch?
To my knowledge you're doing everything correct. Stick the key in and turn to ACC. Push in the lock with the small allen key or a small screwdriver then pull the tumbler out of the housing with the key. Since the key is in ACC, the key itself won't come out but it should pull the tumbler out. Once the lock is pushed, you don't have to turn the key. Just pull.
Old Apr 30, 2005 | 07:02 PM
stale's Avatar
Alright, I was trying to turn like the book said. I'll try to yank!
DirtyDaveW
Dec 1, 2016 05:37 PM
Heathen1
Jan 2, 2016 04:27 PM
timmy39120
May 2, 2015 05:12 PM
robcarnut
Mar 20, 2015 03:40 PM
Jul 4, 2005 05:00 PM
