BBC in a 81 Camaro
Old Apr 20, 2005 | 01:42 PM
Ucantcme57's Avatar
BBC in a 81 Camaro
Anybody know of a K-member built for this purpose? Any ideas or parts needed for this besides 81 and BBC?
Old Apr 20, 2005 | 04:34 PM
1984camaroz28's Avatar
Re: BBC in a 81 Camaro
stock
Old Apr 22, 2005 | 10:03 AM
70modelz28's Avatar
stock works fine.
Old Apr 22, 2005 | 11:47 AM
Ucantcme57's Avatar
No problem with clearance issues under the hood? Sweet.. Thanks guys
Old Apr 22, 2005 | 02:51 PM
angel71rs's Avatar
If you use 350 mounts, it will sit about 1/2" higher than factory BB mounts. Not a huge deal, but add a high rise intake and it makes it hard to get enough air cleaner under the stock flat hood.
Try one of these to deal with problem:
http://www.geocities.com/angel71rs/c...?1068670689170
... but not from Unlimited. You can see some issues in the pic. I've adjusted it some so it's not as bad, but still not a very high quality product.
Old Apr 22, 2005 | 04:54 PM
markinkc69z's Avatar
You'll also have trouble with an hei sized distributor with small block mounts, and possibly the brake booster. Lots of factory big block cars offset the engine to the passenger side an inch. Just something to think about.
Old Apr 25, 2005 | 06:07 PM
OTLRacing's Avatar
also if its a gen VI block the oil pan might not clear , you might need an after market pan.
Old Apr 25, 2005 | 06:14 PM
lt4 fd's Avatar
So you guys are saying a big block will mount up to small block mounts???
Old Apr 25, 2005 | 06:18 PM
Mount? yes more than likely. Fit worth a damn? Not much of a chance. Check the brand of header you want to use and see if they specify original 70-72 mounts or small block mounts.
Old Apr 25, 2005 | 06:25 PM
OTLRacing's Avatar
ive heard a bbc will mount up to sbc mounts pretty easily, u might have to notch out the mount for header clearance but that probably it
Old Apr 25, 2005 | 06:27 PM
then you should go over to ucantcme57's house and help him put it in...lol. Headers and all.
Old Apr 25, 2005 | 07:04 PM
ProstreetCamaro's Avatar
Otlracing = Prostreetcamaro, I Would If I Didnt Live So Far, Maybe U Should Lol
Old Apr 26, 2005 | 12:19 AM
Have you ever seen the potholes in michigan? some of them have headstones....
Old Apr 26, 2005 | 03:29 PM
Ls1smlblck's Avatar
Go to nastyz28.com. It's an all 2nd Gen board, and there are plenty of members with that combo. They'll get you on the right track!
Old May 2, 2005 | 10:38 AM
rscamaro73's Avatar
I just posted about the BBC swap...do a search for today from me
CARiD
Jan 14, 2015 04:00 AM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
1LEThumper
Jul 14, 2003 12:45 PM
Caps94ZODG
Sep 7, 2002 10:09 PM
