HELP new motor, runs like crap
Old Mar 13, 2006 | 06:25 PM
94B&RZ-28's Avatar
Just rebuilt my 327 "mildly" and noticed it had a spread bore manifold and a square bore carb. Can this be a problem? I have the adaptor plate--should I use it? The damn motor has no guts and pings!
Old Mar 13, 2006 | 07:15 PM
Stephen 87 IROC's Avatar
Re: HELP new motor, runs like crap
Without an adaptor plate, you can't bolt a square bore carb onto a spreadbore manifold. One of them needs a dual bolt pattern and even then there may be a problem if the proper gasket isn't used.
As for how it runs, you'll need to do some basic troubleshooting. Pinging is a timing or octane issue.
Old Mar 13, 2006 | 08:23 PM
BitterOldMan's Avatar
or a lean condition causing the cylinder temps to skyrocket and leading to pinging
Old Mar 13, 2006 | 09:14 PM
84firebird's Avatar
spreadbore wouldnt allow 2 of the squarebore barrels to even openeven if you got it to bolt up somehow, check summit they have adapters for like $20 er somethin, otherwise ebay, or get a recently ran quadrajet off of somethin at the junkyard
squarebore and spreadbore just simply dont mix well though, you're probably best off getting a spreadbore carb if you keep the manifold, cuz i ran an adapter, had hood clearance issues (now i have a hood scoop) and it caused some funky turbulence in the manifold, but yea that's why it runs like crap, I'm amazed that it even runs at all
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
